M35A3 Air-Filter
rustystud
3,392
Woodinville, Washington
Does anyone know who sells the air-filter for the M35A3 besides the surplus dealers who want over $100.00 each for the filter ? I think I found a filter that might fit from WIX that sells for $60.00 ea but I would really like to use the original if at all possible.
SRB1976
9
Hanna, Wyoming
Looked up the part #s for both the Fram and Napa. The Napa does not look like the correct filter so maybe I got the wrong part #? Looks like Wix makes one too, part #46845. OK I found the correct napa filter #6845[h=1][/h]
rustystud
3,392
View attachment Scan0032.pdf I checked the specs on the Wix filter 46845. It does not fit the housing. I found another filter from Wix 46908 that is pretty close. The correct filter W250C300 has these dimensions. Height 21" (with gasket), Width 8" and inner diameter of 4.25" (meaning it is 1.75" thick) . The Wix filter has a Height of 21.5" , Width of 8.125" and inner diameter of 4.83" (thickness of 1.64" ) .
This filter sells for $60.68 . To bad the other filter 46845 will not fit as it sells for $27.00 . At least it isn't $100.00 like the original filters are selling for.
SRB1976
9
Hanna, Wyoming
View attachment 602313 I checked the specs on the Wix filter 46845. It does not fit the housing. I found another filter from Wix 46908 that is pretty close. The correct filter W250C300 has these dimensions. Height 21" (with gasket), Width 8" and inner diameter of 4.25" (meaning it is 1.75" thick) . The Wix filter has a Height of 21.5" , Width of 8.125" and inner diameter of 4.83" (thickness of 1.64" ) .
I'm full of all kinds of bad info tonight:-(
