- 3,317
- 3,530
- NORTH (Canada)
Any standard ether start can will fit. NAPA or truck stop (although the newer trucks no longer use ether start systems). Tractor supply might have them, too. You should be able to identify the ether start solenoid the can screws into (can stands upside down) and there is a bracket to hold it in place. There may also be a second bracket to hold a spare can.Hi,
New member first time poster. We just purchased a 1991 M929A2 Dump and the cold weather either start can is missing and I can't seem to find any info on it. I believe it might screw into the cold start housing but not sure. Its located under the hood above the drivers side inner fender, Any info on the can that fits it would be helpful. Thanks and great informative site.
