dusterdeere
- 0
- 6
- grove city Pa
I've got a pair, but have not yet installed them. I had planned on installing them insideView attachment 603967has anybody installed these lights. how did you wire them? ...
Yes, I used power diodes on my indicator light to prevent back feeding my high or low beams.
I borrowed (stole) that idea from you, Artisan.
I like "ALL" of it.I wired up a set for my M-42 Command Truck. I used a waterproof, military DTDP switch with a switch cover. If the switch is in the down position I have low beams; if it is in the up position I have high beams. I got both the clear and IR lenses when I bought the lights from ZiggyO.
Here is a picture of the front of the truck with the added lights (everything is a bolt on mod that used the stock, standard bolt holes - everything can be easily removed and returned to stock without having to weld up any additional holes).
I also included a couple of pictures of the switch plate I built with some dimmable indicator lights and a rear view of the switches I used. The switch plate bolts to the lower lip of the dash.
View attachment 604005View attachment 604006View attachment 604008View attachment 604007View attachment 604011View attachment 604010View attachment 604009
