Special T
- 21
- 18
- Wetside/ WA
The reason why many combat/bolt together wheels fail when running a tub comes from the fact that the hole in the wheel and stem of the tire dont line up very well. It normally causes a small tear next to the stem on the tube lowering the air pressure as you run them. Spinning tires,lower air pressure and loads make it worse. Speed weight and distance determine if that tire will last. Imo id run them tubeless for lots of reasons with that wheel.
