- 206
- 1
- 18
- Freeport, FL
Well, here it goes. I got almost everything i need, with the exception of time, to start my 290 big cam swap. I got this truck with a "Engine will not start" rating from Kansas. Picked her up for a song on GP. Got it home and realized it had main or rod bearing that was a little too tight on her re-build. It ill turn a 1/4 turn and then stop. So, the verdict was to swap it for a little more power.
She started out as a 923. The truck is virtually new, with 0 miles on the odometer and 9 hrs on the hour meter. Every inch of the truck is straight, rust free, and clean as a whistle, with the exception of the oil! I plucked the bed to remove one of the lockers from the rear axle to sell and fund part of the build. I am 86-ing the back axle anyway for now to do my bobber.
I found this 290 cummins (literally a barn find) and off to the races I go. I figured i would start this thread and hope to get any pointers and give any pointers that i can along the way. I have talked to a few of you out there that have done it and am ready to go. After the motor comes bobbing, crew cab, air bags, Axletech 4000's, 53" michelin's and a few other mods i have in mind. It ought to make for an interesting year! I look forward to getting any feedback i can from all of you and may need some help if any of you are not doing anything!&$! Oh, i have a crystal clean NHC250 I am parting out. Let me know if you need any parts! Also will sell whole. All you would need to do is possibly one crank or rod bearing and she is ready to go.
