cucvrus
- 10,467
- Jonestown Pennsylvania
It's totalled?Thou shalt not remove large snow piles with heavy equipment when one does not know the lay of the land or what is behind the snow pile on the back side. This is a new truck that was sent back from a new car dealer. it is not fixable. It is pretty new and it has been totaled. The loader operator was a contractor removing snow piled at a dealer and hit the front end after someone pile snow in front of the white van.
Oil is cheap so if she starts run her.Today I used the Voodoo M1009 to do some grading. I drag a steel beam section behind it in 4 LO. The plow pictures will not load but the engine pictures did. This is a complete stock M1009. I have been running it off road since 1999. It has a lot of oil residue at the oil fill and I had it out on the highway about 2 times in the past 17 years. I just had an entire new exhaust system and 4 new Firestone tires put on it before the start of winter. Check out this engine.View attachment 615354View attachment 615353It runs 40 hours minimum a week and stays on a 50 acre stone/dirt lot. Very few days absent from the job. It does use a quart of oil every week and when I get a chance I run it around in 4 lo so the engine can get cleaned out a bit. When I had it out on the road it smoked so bad you could not see behind me for the first 7-10 miles. That cleared up and it ran like a different truck. Have a nice day.
Sad thing is it wasn't gm that came up with that, it was an aftermarket bumper company that did, gm finally got the hintGM got smart and built steps in the corner of the new pick up rear bumpers and hand holds in the rear bed corner pockets. WOW how easy was that? It took that long to figure that out? Happy Holidays.
