BlazeKeeper
- 0
- 0
- Tennessee
Hello,
I posted one thread already about turning an M998 into a fire department brush truck, and you guys helped tons already. The rivnut fixed the mirror bracket. However, since we're still in the process of working on this and will run into other problems I'm sure, I'm creating a general question thread so I don't clutter the forum up.
My current problem is with the brake lights. They work (after much aggravation), but they don't come on unless you really stomp the brake pedal. On a normal vehicle they would come on if you just barely pressed the pedal, but not on ours. Is there a way to adjust the brake light switch that's hooked to the pedal to decrease the travel it takes to activate the lights?
Thanks!
Thanks!
