Bandit02
- 4
- 0
- Blind Bay, BC
Sooo, today I went about replacing all 3 diff breathers and found 2/3 stuck closed. They let go a bit of air pressure from within when I removed them. I have since run straight barbed fittings with 3/16" rubber line to act as the vent now. This may explain why the front diff was leaking out of both axle shaft seals and a pinion now.
Anyways, I noticed there is no breather on the transfer case. There's a vent line to the intake stack for the shift solenoid but not the housing itself. I recently replaced the rear output shaft seal behind the parking brake. It was dry for about a solid month and now it's slightly leaking out of that weep hole.
Has anyone put a vent on and and where did you install it?
