Smokinyoda
- 8
- 18
- Franklin, NC
I've been stuck in Salem VA since around noon today. Possible compressor failure. Had been driving fine for almost 4 hours then ABS light came on. A little later all CTIS lights start flashing, then my wiper quits. So I pull to check things out. PPV valve not leaking, pulled guts out, started truck and get very little air flow. Pulled supply line off dryer, very little air. I could actually plug the hose off with my thumb. Back up to compressor and took small line from unloader off, sprayed wd40 in and tapped on it for awhile with small hammer. Did I mention it's been raining this entire time? lol
Thought about gaskets on the head but I can't feel air leaking anywhere in that area. Is there anything between the pump and dryer that could be the problem?
Aside from head gaskets, or stuck unloader all I can figure is a bad compressor.
Any other suggestions? The one time I don't bring my laptop with the TMs something finally happens that I need them.
Posted a want ad for a compressor in classifieds. I also tried a small compressor with a large inverter but it kept tripping. Going to try and find a generator in the morning that's big enough to run compressor. Plug into emergency glad hands maybe I can at least get home.
