Would it be possible to swap 2.5 ton axles into an M923a1?
ColtRice17
Tulsa, Oklahoma
Could I swap 2.5ton axles into my M923A1? my reason for asking is Air lockers. something I want to do with the truck requires it to have air lockers. So, can I install the 5 ton hubs and smindles etc onto the 2.5 ton axle housings? I would strengthen them up with Gussets etc. do you see any problems with this idea? would they even be strong enough?
5,066
You could, but the easier approach would be to simply sell your current truck and buy a USMC M939 series truck equipped with lockers from the start.
1,141
gussets, etc.
There is a lot more that goes into an axle's weight rating than the strength of the housing itself. A good example would be the difference in size between 2.5 ton hub bearings and 5 ton hub bearings. The difference is enormous-I don't know the relative sizes off the top of my head, but the 5 ton bearings have to be 20-25% larger.
The 5 ton brakes are significantly larger than the 2.5 tons, but I assume there is probably some way to get around that.
I think what patracy said is spot on.
sandcobra164
321
Leesburg, GA
Lockers are not guaranteed just because it is a USMC M939. Look on the dash or Driver's side door for the "No Spin" lockers dataplate. I've seen hundreds with and thousands without in storage on base. We're down to a small handful now but they're out there. In my experience, the M809 Series had a higher probability of having lockers.
ColtRice17
Tulsa, Oklahoma
good to know. I will do some checking around. it was just something I was wondering about. I'm not hauling heavy loads so changing the load rating wouldn't be a major problem. I just want air lockers and locking front hubs :(
355
12
New Enterprise Pa
the puny kingpins and the small axle tubes are just gonna create a headache of problems. those little kingpins were never designed for anywhere near that weight especially with a stiff suspension as a 939 truck. and a few nasty holes at speed and the ends of the axletube will be bent upward. I've seen many of m35's used for hauling potatos and other farm stuff at low speeds in the fields and the axles look like they are smiling at you.
