Blackmagic94
- 9
- 18
- Oro Valley/AZ
So I have a m1078 with a bad hydro seal which I have ordered. But how can I raise the cab before I replace the seal to address a loose belt issue.
If you have an overhead crane or very tall cherry picker you can life the cab from the rear.. When I did it I disconnected the hydraulic lines to the lift cylinder. It made a mess.So I have a m1078 with a bad hydro seal which I have ordered. But how can I raise the cab before I replace the seal to address a loose belt issue.
Does the manual pump not work?There has to be another way. I noticed on gp a truck that couldn't be started they had the cab up
That means the pump units seals are toast and it's been over filled. I saw that on one of our LMTVI have never heard of it pouring out there though. Fill the reservoir and try the hand pump again.
