Microsoft MSN, Live, Hotmail, Outlook email users may not be receiving emails. We are working to resolve this issue. Please add support@steelsoldiers.com to your trusted contacts.
Hello, I found that my Ether Canister was empty and purchased a new Ether can through Napa Auto Parts. Does anyone know if the threads are different than the military stock number as I am having trouble screwing it down. Thanks for your help. Dennis
I know exactly what you are saying but unfortunately it was trash day and I threw the old canister away. I had no idea there would be different threads? I assumed it was going to be same threads and just screw on. Live and Learn! Thanks, Dennis
That Napa Part #33118 is the ether cylinder I purchased from Napa. It doesn't seem to have the correct threads to screw in unless I'm doing something wrong? Is it possible I have to push down hard to start the threads. It appears that I should have to do that? Dennis
UPDATE/FINISHED! I found out the Napa Either Cylinder (#3311 does have the correct threads to fit the M1078. Even though my old empty cylinder screwed off easily the threaded base was not lined up well. I had to actually loosen the lower mounting bracket to allow the base to line up with my new Napa cylinder and it screwed right on. Problem solved and hope this may help the next guy. Thanks for all the replies.
