gimpyrobb
dumpsterlandingfromorbit!
- 27,786
- 755
- Cincy Ohio
Or just spin it over with the starter, no fuel involved. With the others out of their bore, the motor should spin quick.That is a common trick in the heavy equipment world. Loosen the injectors and then start the engine. Usually they all come busting out of there bores and spraying all over the place. Of course you must shut the engine down quickly ! Sometimes the hold-down bolts will break though so be careful if you do try this trick.
