Dock Rocker
- 71
- 28
- Jackson ms
I have seen guys use several layers of weather stripping under the bulkhead. This keeps out the breeze to a certain extent and it also keeps the water from pouring in.
When I installed my new top, there were two wire brackets that got installed on the floor and the straps/cambinders attach to that. But the MV tops on a HMMWV I think will all leak by design.It seems my question got merged into another thread. Sealing the bulkhead is only part of the solution as the curtain is on the inside of the bulkhead ,the wind and water kind of has a pocket between to run into and then under the bottom of the curtain. Still leaving the question of how to seal the actual bottom of the curtain to the floor. Or maybe somehow seal the curtain to the top of the bulkhead? Thanks to everyone that has replied.
