richingalveston
- 120
- 63
- galveston/Texas
I built a mount for my cb antenna and a small led cube light. I made one for the drivers side also but have not finished it yet. I still have to buy the lights so I won't install it until I get them.
They will be powder coated or painted to match the truck. And the antenna is getting a 4 inch spring base.
I would consider having these made in bulk (could be much nicer fabrication) if people were interested in them. You do have to trim the mirror base cover for the bracket and any wires you want to run. It is very strong.
I already have the rubber sleeve in the door for wiring. I have already added power windows and locks. You could run the wire through the vent window or up to the hood but through the door works best.
