Corvette1974
- 1
- 18
- Upper Black Eddy, PA
Hello All,
Just changed the fluids on the M35. All of the fluids came out as expected - dirty and slightly metallic, probably hasn't been changed since 1990 overhaul. The rear axles were definitely the dirtiest with the most material on the magnets. The rearmost axle actually had two pieces of metal come out when I drained it - They seem to be hard (probably steel) and are about 3 inches long x 1/16 inch wide and about 1/16 thick and seem to be from something round (they are half circles).
The truck doesn't have any major leaks from that axle, nor were there any weird sounds from the truck. Center driveshaft doesn't seem to have any excess play.
Any ideas? Is this safe to run? Maybe just junk from an overhaul? I can post pictures if needed.
Thanks,
Will
Thanks,
Will
