goldneagle
- 1,521
- Slidell, LA
What model trailers take a Super-Lug 9.00-16 tires on 16" 6 hole rims? I know the M116 and M101 trailers can take the tires but not the rim.
I just looked up the M200A1. The rims are 6 hole but are 10R22.5 14PR Tires, not 9.00-16sI saw these type tires mounted on M200A1 generator trailers. If I can find the right TM, will let you know.
Could not confirm your suggestions. M200 trailers I found use 20" and 22.5" rims. Yes some had a 6 lug pattern. However my rims are 16" 6 lug 1 piece rims. M1101, M1102 and open chassis use 8 lug wheels.I amended the text.
These are 16" not 16.5" one piece rims.The old time "civi" International & Dodge 3/4 & 1 ton's used that wheel hole pattern, but mostly were found with the lock rings. Some one piece wheels did exist, as I once bought a "Binder" 3/4 ton with 16.5" tires. Mostly the 1 tons had duals.
