- 179
- 19
- 28
- Gilroy, CA
Spent the last few days making a converter dolly out of a 5ton bogey and a MK back half towbar. Have most of it finished up now except for hooking up the brakes, and thats where I'm needing some help.
The bogey had no relay valves, or plumbing besides the lines that ran from the top of the chunk to the brake pots when I got it. The bogey was from a non ABS truck, so I started robing parts off another non ABS chassis. Now all the lines are hooked up between the relay valves and the brake pots.
Where I'm stuck is getting the service and supply lines properly hooked. Whats really got me turned upside down is the brake brake system has provisions for the "spring brake override" button on the dash. Most brake pots have two ports, but ours have three. I think it is because of this feature?
Also, does anyone know the model of these relay valves so I can look up a diagram?
Thanks for any help!
