M35CAT
- 0
- 3
- Newark, Ohio
I have a M931 Truck and found a set of LMTV wheels and tires. Will these wheels and tires fit my 5 ton? Thanks for any input.
Are you sure? I am under the impression they are the same 10 on 11.25" as a 5 ton.No different bolt pattern.
No need to apologize - where it gets really tricky is the wheels from the Caiman MRAPs that have the same wheels and bolt pattern as the FMTV. They are "MRAP wheels" that fit a 5 ton, but aren't the "standard MRAP" 10 on 13.25" pattern.Yup I looked at the guide you are right the bolt pattern is the same. The mrap wheels are different sorry.
