Torque values for M939
Csm Davis
403
Hattiesburg, Mississippi
Can someone please help me find the torque converter to flywheel bolts torque specifications I have looked and at this point I can't find them and yes I know that they are in the TM but after several thousand pages I give up
Swamp Donkey
The Engineer
123
Gray, GA
Look in the -23-2 TM in Work Package 220 & 221. Not sure whether you needed for the 8.3 or the NHC250 but both are covered there.
Swamp Donkey
The Engineer
123
Gray, GA
Sorry Jeff, wrong bolts in the above post.
You need Work Package 372-8 from the -23-3 TM.
Install 12 screws (Figure 6, Item 4) on flywheel (Figure 6, Item 1) and converter (Figure 6, Item 8) in the same manner. Tighten screws 41 to 49 lb-ft (56 to 66 N·m).
