lube order card 5 question
reaper556
HOCKLEY, TX
I was greasing my 1028 today and finally went and purchased a needle nozzle so I could get the fitting on the constant velocity joint near the tcase. The lube order if im looking at it right shows a fitting for the front prop shaft slip joint near the ujoint closet to the front diff.
Is this fitting under the boot?
blueblaze
Chapleau, Ontario
Shouldn't be. Truck probably got a new shaft in its life and there isn't a grease fitting for the slip yoke. I have a few shafts, most have the fitting but I noticed 1 of my newer reman shafts doesn't have one.
