GunnyM1009
- 530
- 93
- Roanoke/Alabama
Lead Acid Battery Restoration (Experiment)
So a couple of years ago I bought a large D8 1000CCA battery for Gunny. This was when I was having alot of Gen2 issues. After about a year of being drained and charged I couldn't get it to hold a charge again. Well I pulled it out and put it on the ground by a tree where it has been for over a year. Most of that time it has had a large ant bed built up around it. So I had been seeing things here and there about different ways to rejuvenate batteries so I began to study on the subject. I got the battery and brushed all the ants off of it and used it to test my knowledge. I popped the caps off and poured out a little of the liquid and replaced it with some Epson salt and distilled water. The epson salt was dissolved already in the distilled water. I replaced the caps and put the battery on a cheap desulphator that I bought online. Then for 3 weeks I would trickle charge the battery for 24hrs then let the desulphator run for 24hrs. At the end of the three weeks I left the trickle charger on the battery for 4 days. Its a smart charger so it told me when it was done. I pulled the charger off and after several hours the battery settled to 12.75 volts which was promising. I had a blinker fixture that had recently been removed from a motorcycle. I hooked it up and the battery only dropped to 12.52 under a small load. Well lets go for broke I put it in the forward battery position on Gunny held the GPs for about 8secs and he turned over strong and crunk up. I have ran it for a couple days now and all seems well. I will keep updating over time to see how this works. If all keeps going then I saved a $190 battery for about $20 dollars thats with the purchase of the desulphator. This is not an instructional how to this is just what happened for me. If you would like to try it do the research and take proper safety precautions you are messing with lead acid batteries still.
