- 1,969
- 232
- 63
- Arizona
The passenger side tire on my M916 is wearing in a weird pattern. The driver's side tire does not display this and is wearing just fine. The toe is set correctly and I have run between 90 and 105 psi in the front tires.
There is one stripe that is worn away around the entire tire and several points towards the center of the tire contact patch that are worn as well. The dark area in the tread in the photo is where the dirt is not sticking to the tire. This all happened within 3000 miles on a new tire. I don't think this is indicative of too much or too little air pressure. Usually too much air pressure shows up as a worn spot down the center of the tread, not towards one side like this. Too little shows up as worn edges and that is not what is happening either.
The front tires have quite a bulge in them, almost like they're low on air, even with 105 psi in them. It is to the point that people say "hey, that tire is low on air." Maybe this is because there is so much front axle weight? One time I got a tire back from being worked on with 120 psi in it and I mounted it on the truck before lowering the pressure and it had the same tremendous bulge as 90 or 105 psi does. The TM says 90 psi for the front tires, but that is likely for the 11.00x24 bias ply tires that were originally OEM on the truck. I have run 105 psi in the tires also, which is the max allowed by the stock wheel.
Maybe its a balance issue? I'd say lack of shock absorbers, but the other side is doing just fine. The spring looks okay and measures the same from spring to frame on both sides.
Any ideas?
Any ideas?
