Asmoday
- 0
- 16
- Los Angeles, CA
M1009 Electrical Bizarro Problem - Need Guidance and help...!
Hello all,
I haven't posted in a while but I have been lurking a bit...
I now have a major issue with my M1009.
This AM I went out to start her up...waited for the "wait" light to go out...turned the key...got a quick starter engage and that was it....everything went dim. I turned off the ignition and back on again and now have the repeatable scenario in the video that follows.
When I first turn on the ignition the Volt Gauge reads nothing but eventually begins to show activity. The appropriate instrument lights glow very dim.
Play close attention how the system eventually seems to return to normal but once I turn the key to try and start it...it starts it's weirdness all over again.
The video is worth a thousand explanations...
View attachment Cucv-1.mov
The batteries tested out fine but I went ahead and put a new fully charged battery in the rear and the scenario is the same. The driver side alternator was replaced new about 4 months ago.
All the 12v and 24v voltages measure correctly with a Fluke meter at the normal points but once I turn the ignition on and the glow plug relay starts chattering the voltage drops to between 4.5 - 5 volts.
It has the Doghead starter relay mod as well as the glow plug relay mod. The electrical system has been near perfect until now....
I'm definitely going to need some help and guidance on this one...!
Thank you,
Adam
Hello all,
Thank you,
Adam
