BackWoodsDrifter
- 0
- 6
- Bloomsburg/PA
I run my wmo through a 1 micron filter (Final)then centrifuge before I put it in the tank. It settles in 55 gallon drums for a good while until I put it through the centrifuge and heat it to get the water out. I reckon at 1 micron I am already below what factory specs on fuel filters and should be in theory "cleaner" than pump fuel, however there is still the fine black (Stiction?) that makes the oil black not gold as mentioned. Going to be running spin on filters for the fuel too here when I get round buying them and the ground stiffens up to comfortably work outside. Not saying its better or worse, but that's what I have been doing during the summer months once it gets below 60 I start running majority of straight diesel.
