3 phase 208 help
Kemp3
Carmel Valley
I apologize I have searched and found nothing on this subject. I have a 15 KW heater that I am trying to use to load test my MEP-803a . The heater has Black (L1) , Red (L2) , White (L3) and ground wire, In 3 phase 208 settings on the 803 I cannot get 3 legs unless the N is acting as the third leg ( which is barred to the ground still). Is it safe to wire up with the Heaters White (L3) connected to the 803's N ?
Thank you
Kemp
Triple Jim
334
North Carolina
Doesn't the 803A have four output lugs like the 003A? On the 003A there's L0, which is neutral, then L1, L2, and L3, which are the three phases when in 3-phase mode.
Kemp3
Carmel Valley
I guess L0 is neutral but there is no setting that I see that uses L1,L2 and L3 simultaneously. I can pull the heater access panel to show you the L1 - Black L2-Red and L3-White that runs through to T1 T2 and T3 if that helps .
-Kemp
kloppk
4,130
Pepperell, Massachusetts
See page 2-2 in TM 9-6115-642-10 for terminals used in 3 phase.
Also see the electrical diagram on page almost at the end of TM 9-6115-642-24.
It's F0-1 Electrical Schematic and shows L0
Kemp3
Carmel Valley
Then I must be misunderstanding the AM/VM switch , this heater should not have a neutral . I guess I will try Black to L1 , Red to L2 and White to L3 and see if any switch settings allow it to work .
AfghanVeteran2010
29
Odessa/Texas
Here's a wiring schematic
It sound like there are using the white wire for power as well, you should see where those wires hook up to.
edit: schematic says cable not included.
Suprman
707
Stratford/Connecticut
That heater may just use the 3 legs and a ground. I have one of those it makes a good load bank. It will draw a bit more than listed and the mil generators don't always trip on over current right away. That kind of load can damage a 10kw gen at full draw for too long.
kloppk
4,130
It's not the AM/VM switch that sets the 803 to 3 phase mode.
You need to set the output voltage phase selector switch that's on the back wall inside the meter/relay compartment.
Gotta drop the meter panel open to get to it.
Kemp3
Carmel Valley
Sorry I thought the AM/VM switch had something to do with output besides the phase selector. I have the phase selector set to 3 phase 208 , I am now guessing the AM/VM switch really only has to do with the sense gauges on the panel for monitoring.
Thank you
Kemp3
Carmel Valley
With everyone's input I was able to better understand the gen and have it wired correctly. Good news the gen will output 40.6A on all 3 legs @ 208 , bad thing is that is 120% load and protection doesn't kick in . Now I need to come up with a way to vary the load via the 15kw heater to use as a load bank and not be running a constant 120% while testing.
Thank you all for the help
-Kemp
Daybreak
2 Star Admiral
1,522
774
Va
Howdy,
Check out my load bank thread with the logs which I made while testing.
The military suggest putting a 133% load on the unit for a short duration to ensure it is ready for 100% load 24/7
Triple Jim
334
North Carolina
Congratulations on having a great running 803! Putting out 120% of rated load without tripping anything is not a problem you need to fix. :beer:
