Headlight issue
1euro2c
Palmer Alaska
Original headlights work fine high and low beam. When I replace with brand new LED truck lights they won't work. I plug the 3 corresponding wires and nothing. Any thing I'm missing?
MtnSnow
14
NSL, UT
Are you sure that you have all 3 wires connected tightly and the wires match up correctly. Have you tried to bench test the new headlights to make sure they actually work?
1euro2c
Palmer Alaska
Yes Sir. I am sure I connected them in the right sequence and tightly. Can't bench test as of this moment but I will when I get home in 6 days. Just really wanted them working when I go thru Canada
tburk49760
10
spokane washington
I had a similar issue. The wires on the back of the headlight housing were plugged into the wrong connector. The wires on the back of the housing and should be numbered and that should correspond to the number on the front of the housing where the headlight plugs in. Good luck you need to be multi faceted double jointed and quite flexible.
coachgeo
3,462
North of Cincy OH
Lmtv headlights are 12 volt. If you got the mil surplus trucklites many are 24 volt only.
Do you recall if there is a thread or two which discuss what is 12v and what is 24v on these rigs? Got a hint for good key words to search by to find them if so, or links? Most boards wont search by 3 characters like 12v or 24v but will try
gentycam
lithia florida
My headlights on my 2003 LMTV are 12volt. I have some led lights I put on my deuce and they're 24. They won't light up on a 12v system.
Overdrive
96
Wentzville, Missouri
The fuse panel diagram in the back of the cover pretty much tells you what is 24v and what is 12v. A multimeter is your Jedi tool on an LMTV too.
