Blythewoodjoe
- 56
- 28
- Blythewood, SC
Ok, here we go. I have searched and can't find the problem. So here's what happened:
truck has been hard to get cranked for a while. The last time I had it cranked it ran for about 30 seconds and died. It is not uncommon for it to do that. Tried to fire it back up and no fire at all. Have been trying to crank it for weeks. Has not attempted to fire up at all.
I my first thought was to look for a fuel leak. My old M813 had a leak and it was almost impossible to crank until I found the leak. I found the leak in the M813 years ago by putting a little air pressure on the fuel tank. I did the same here and it will push fuel out of the big line (supply line I assume) on the pump. With everything hooked up it leaks no fuel anywhere. I tried to use the cold weather starter in the cab but will leak fuel if you pump it up, but it does not leak fuel with a little pressure on the tank. I removed the selinoid from the fuel shut off only to discover it was nothing like what I thought it would be. I put it back together and gave up. I know a lot about a deuce multi fuel engines but this cummins has me lost. In fact I can't find the injectors. Help.
Thanks
Thanks
