mikey
- 39
- 28
- Lake Como, PA
Hello,
I have Peter Debella's brake kit for my 53 M38a1 which includes a new mc, wheel cylinders, rubber brake lines and brake pads.
Is there any reason why at this point I would NOT want to convert the jeep from dot3 to dot5?
If the conversion is recommended, then what is the best process to flush the system of dot3 now? I assume I'd want to flush it with the old lines and cylinders in place, but what would I use to flush out the dot3, denatured alcohol, methylated spirits, anything else? Keep in mind, only the copper lines will remain. All rubber lines, the master cylinder and wheel cylinders will be new.
Thanks
Mikey
Thanks
Mikey
