Locked Up 6.2 Diesel
cucvrus
10,435
Jonestown Pennsylvania
Any tricks to get the 6.2 diesel out when it is locked up tight? I have the heads and pan off 5 connecting rod caps disconnected, all the main bearings and caps removed, the timing chain and gear. It is basically a block. I would not fuss so much but I could get 5 of the 6 torque converter bolts. But as fate has it the one with/in the weight on the flex plate is at 12 noon on the crank. Dead center top side. That and I got struck in the thumb with shrapnel when I was hitting the pistons from the top side. It bleed like I hit an artery. Stop production. Fall back and regroup. I took a break to regroup and come up with a strategy. Another plan of attack. This engine is coming out today.
doghead
4 Star General /Moderator
1,179
Why not pull the motor with the flexplate and torque converter still attached to the crank?
Recovry4x4
LLM/Member 785
1,808
GA Mountains
This! I'll have to say though, that bolt surrounded by weights is a real PITA, removed one yesterday. Have you tried one of these?
doghead
1,179
Just don't install it assembled, as you can damage the pump.
cucvrus
10,435
I have that fly wheel turning tool in the Snap-On version. This 6.2 engine was locked tight. No problem. The answer was right at door.DSCF6874.jpgI wheeled out the oxygen /acetylene torch and cut the offending connecting DSCF6885.jpgrods off. Worked like a charm. No burns I put on my PPE. I do not like pulling engines with the torque converter attached. That is hard on the front pump and the transmission. You need an exact angle. I know it can be done. I have done it hundreds of times but not when I am going to be putting it back together. Maybe at the salvage yard/can point. Even at the YOUPULLIT I try my best to do extractions the right way. Some other poor guy may need the attached part that I just opened up to the elements. I worked harder then I had to but I achieved the desired goal. Thank you for advise. While you were giving it I was torching.
doghead
1,179
After seeing that you started a new thread on your humvee, I moved this thread to the correct forum.
You could not have had easier access to simply slide the engine forward, and save all that torch work, but to each his own, yadda yadda yadda...
cucvrus
10,435
I love torch work. And I asked about the locked up 6.2 engine because it is the same engine as a CUCV and I am familiar with a CUCV. Just a little not as well as you. I will have to study and work much harder to keep up with you.master.pngMaster.
