M1101, M1102, LTT-TQG Trailer Jack
Daybreak
2 Star Admiral
757
Va
Sure... NOW you post it... a few weeks after I was looking for it. :p
Howdy,
I picked up a 5kw on a trailer (2009 PU-797C (5KW on a LTT-TQG)) That's because someone did not put the jack pin in, and it rotated and bent the handle. I just happened to look over at my batwing bush hog, and noticed the sidewinder bulldog jack they used, the handle looked really identical. I took the bulldog jack apart and realized the gears and the handle were the same. I ordered it, and put it on. It's nice too, since they also include the hole bushings.
Daybreak
2 Star Admiral
757
Va
drivebymashing
51
North Carolina
I also just purchased the curt jack. I will bolt on the factory jack wheel. It measures the same length supposedly. I will post my findings.
Fits factory mount. Same length. I have it on a block because I was unloading wood chips wanted more angle. 44 dollars shipped on amazon.
Daybreak
2 Star Admiral
757
Va
Howdy,
I only know that the jacks I have on my trailers move around very easily on asphalt and cement.
Daybreak
2 Star Admiral
757
Va
Howdy,
It is really easy. Take the 1 bolt out, take the cover off. Take the roll pins out. Put you new stuff in. :) Grease it up, put it all back together.
crackerjack
Florida
Thank you for the information in this thread. I am going to fix my original jack at this point, but if it becomes a problem in the future, then I know where to get a commercial equivalent.
Tinstar
1,738
Edmond, Oklahoma
Anyone have the NSN or part number for the complete jack assembly?
The trailer TM section does not have the M1101/2 TMs.
edit; Its there and guess I was more tired than I thought and missed it.
Tinstar
1,738
Edmond, Oklahoma
He sold them all if that’s want you wanting to know.
They are available commercially by same manufacturer.
Only difference is the steel wheel isn’t bolted to foot.
Tinstar
1,738
Edmond, Oklahoma
FFF32081-F519-4934-B63B-A6AAC954CC62.jpgC44C668B-DCF4-4325-A735-C55286A1FD3C.jpg8E9F99B8-FFA6-4429-9E79-981B0F2C3A9B.jpg7088CE4A-9EA9-40B1-8D23-FB7EF309411F.jpg
The NSN search brings up Butler products as the manufacturer.
This is the M1101/2 civilian equivalent, made by exact same manufacturer.
No it doesn’t have the wheel, but I can live with that. You can always install one.
They are made in the USA and are excellent jacks.
Mine are 5k rated. Have them installed on each M101A2.
Spare parts available.
FYI
Jetred
Triangle,NC
I found a jack built for Schutt Industries at SurplusCenter.com .Ordered one and other than the extension below the foot it's the same as the original. I cut the extension off and the flat foot allowed me to drill the holes and bolt the wheel from my old jack on. $28 is cheap for the jack, but their shipping tends to be high. Still the best replacement I've found.
http://www.surpluscenter.com/Truck-...-lb-13-Lift-Side-Wind-Trailer-Jack-1-4683.axd
Joneswill
Salisbury NC
Howdy,
I have found some good replacement parts.
Trailer Jack Handle Replacement Bulldog Sidewinder Handle part# 100105
View attachment 623647View attachment 623648
View attachment 623649View attachment 623650
Inside Gears
Bulldog beveled gear set Part#500106
Push-to-release pin 5/8" x 2.5"grip L handle
View attachment 623652View attachment 623653
Ready for action, Trailer Jack
We’re can I get a jack for my M1101 the gears are missing teeth?
