True Knight
- 179
- 43
- San Pedro, CA
I got the troop seats back together. Thanks to the TM, new wood slats to replace the broken ones and all new hardware it should last a long time.
Those are looking real good. And a nice paint job all around, too.I got the troop seats back together. Thanks to the TM, new wood slats to replace the broken ones and all new hardware it should last a long time.
Thanks. I ran out of rapco 383 so I painted the rest with one of the rustoleum camo green colors. It's a bit darker but it doesn't look to bad.Those are looking real good. And a nice paint job all around, too.
Is your camping gear going to fit in there with the seats or are they easily removable?I got the troop seats back together. Thanks to the TM, new wood slats to replace the broken ones and all new hardware it should last a long time.![]()
What is it about that last pic ?SM465 swap is complete. Everything worked out fine. Seems to drive just fine, not had it on the interstate yet.
Today I replaced the steering stabilizer and front shocks to try and reduce the death wobble. Replaced the temperature sensor so my wait light would not come on when the engine was hot. I think that this is what led to a glow plug tip expanding and breaking off in the head. Also, replaced PCV Valve and changed oil and filter. About to start on installing a new hitch and brake controller.
I am in the same boat as you. I really want to swap out tires and be done with it but with retirement and relocating my family, they are going to have to wait a bit. This truck is looking how I envisioned it and more importantly, it's doing all the tasks I had hoped it would. Thanks so much for the compliments.What is it about that last pic ?
That's a great looking truck !
Cant wait to see matching tires on the rear.
Wow. That will do it!![]()
This is how you fix death wobble
Yep best bang for you buck thing you can do to a kingpin 60Wow. That will do it!
I just used 1 large washer on each side. Worked just fine.![]()
They fold up and are easily removable.Is your camping gear going to fit in there with the seats or are they easily removable?
I like the adjustabilityI just used 1 large washer on each side. Worked just fine.
At 65 my 4.56 geared cucv with 33 inch tires spins at 3k,70mph it's at 34k and at my top speed of 83 mph it was at 4k.it sees 70mph on a daily basis. I use a GPS for my speedometer.It takes 3k with the 4.11 to hit 60 in your truck?
Is it the box making it slower or what?
Sent from my XT1585 using Tapatalk
Adjustability is good, as long as it doesn't lose the proper adjustment. As long as the proper preload is there (the single washer in mine) it won't need any adjustment for a long long time.I like the adjustability
No maybe not but i didn't Wana put a washer in and have it not be enough and have to blow it all back apart. So I spent an extra dollar on 2 nuts and 2 bolts hahaAdjustability is good, as long as it doesn't lose the proper adjustment. As long as the proper preload is there (the single washer in mine) it won't need any adjustment for a long long time.
Yeah I tried 2 washers first and it was too much. But it was a quick fixNo maybe not but i didn't Wana put a washer in and have it not be enough and have to blow it all back apart. So I spent an extra dollar on 2 nuts and 2 bolts haha
