Rust-Oleum Camouflage Ultra Cover 2X Spray Paint
Daybreak
2 Star Admiral
1,522
773
Va
Howdy,
OK, A MEP-802A mounted on a LTT-TQG trailer Tan.
Not all paints are equal. But for touch-up places, this sure does blend well.
spray cans
Rust-Oleum 279180 Specialty Camouflage Ultra Cover 2X Spray Paint, Sand, 12-Ounce
Rust-Oleum 279180 Specialty Camouflage Ultra Cover 2X Sand.jpg279180 Sand.jpg
and the same product line for the
Rust-Oleum 279179 Specialty Camouflage Ultra Cover 2X Spray Paint, Black, 12-Ounce
Rust-Oleum 279179 Specialty Camouflage Ultra Cover 2X Black.jpg279179 Black.jpg
Can't even find it on the Rust-Oleum website. Picked it up at a local Wal-mart. about $3.75 a can
FloridaAKM
395
Gainesville, Florida
I've been using it as well to fix some rust spots on the air drop LMTV that resides in the back yard. Green is not quite an exact match, but works, just like the brown. The Black & Tan is a perfect match. The sand colored Deuce gets all rusty spots fixed with the Tan & blends in perfectly. Readily available @ your local wally world!
FloridaAKM
395
I noticed on the last can of tan that it would change color & texture while spraying. The can was well mixed, so that was not the problem. It ended up looking good, but was a strange ride getting there!
The green fades quickly and does not hold up well.
I have also had issues with the tan not being consistent color.
Vociferous
Northwest Ohio
I was painting my wheels this weekend and was using the camo black. I ran out of it and had a can of regular flat black, also Rustoleum. And in case anyone was wondering, yes there is a difference in the sheen from flat black to camo black. The camo black has no sheen at all compared to regular flat black. Needless to say I have to cover it with camo black to match. Just an FYI.
FloridaAKM
395
Sometimes, the surface temp of what you are painting has a lot to do with the finish. In your case, you are correct . If you are wanting a flat finish with a flat spray paint that won't cooperate, position what you are spraying in the direct sun & when the surface gets hot, paint it in light coats. If that is not an option, use the camo flat black paint! Just a thought on spray painting flat paint
Jericho
70
Landaff NH
I use the DARK FOREST GREEN rustoleum camo paint all the time, Prime with a good self etching base or the best result I have is with the RUSTY METAL PRIMER SHAME RUSTOLEUM didn't offer it in GALLON CANS, seems silly to only offer in spray bombs
