i thought that the air just made it so you could apply the brakes. once applied and locking the line i did not think air would matter!!Same with air leak down, thats why I was thinking linear actuator.
Your right air leak down wouldn't matter as they get install after the master cylinder and hold pressure from the Mico-lock to the wheels.i thought that the air just made it so you could apply the brakes. once applied and locking the line i did not think air would matter!!
i could be wrong.
They just shut a valve with pressure on the system and hold the pressure , when you release it the fluid goes back to the MC.If you have the engine running during operations, then why not do a modification to the air pack to pressurize it so that it locks up all the wheels? There was a modification done somewhere that people use for when towing a deuce, you can apply the brakes on the towed deuce by the trailer brake line from the towing vehicle. Do something similar. Just pressurize it with a specific amount of air pressure and it will lock the wheels up. Just have to make something redundant do you don't bump the switch/valve while going down the road. I wouldn't mind doing this modification myself. It would be handy.
I don't know how that electric brake valve works with the hydraulic brake wreckers. Is it similar to how line locks work on drag cars?
The only bad thing about them is that the valve can leak down a little and lose pressure on the brakes. It happened to me with my Hurst Line Lock that I have on my Street Rod. It would leak down holding the front brakes locked up. I rebuilt it with a new O-ring and it was all better. If you pressurized the air pack, it would keep the same pressure on the system all the time. It would not be for long term and should not solely be relied on, but it would work well for winching operations while using the parking brake. one just had to know the limits of the system. Don't just pressurize the air pack and use it as a parking brake with the truck not running. Then air leaks down and your truck rolls away.They just shut a valve with pressure on the system and hold the pressure , when you release it the fluid goes back to the MC.
That's a very interesting idea you have there ! It would be really easy to do too since there is already extra ports drilled into the valve area.The only bad thing about them is that the valve can leak down a little and lose pressure on the brakes. It happened to me with my Hurst Line Lock that I have on my Street Rod. It would leak down holding the front brakes locked up. I rebuilt it with a new O-ring and it was all better. If you pressurized the air pack, it would keep the same pressure on the system all the time. It would not be for long term and should not solely be relied on, but it would work well for winching operations while using the parking brake. one just had to know the limits of the system. Don't just pressurize the air pack and use it as a parking brake with the truck not running. Then air leaks down and your truck rolls away.
I forget the exact process to plum the air to do this. It was listed somewhere else in a thread that discussed how to hook up a glad hand in the front of a deuce to operate the brakes... similar to how the 5 ton trucks do it.That's a very interesting idea you have there ! It would be really easy to do too since there is already extra ports drilled into the valve area.
