- 728
- 6
- 18
- New Jersey
What's the number on the metal tag on the wire? Every wire in the truck has a tag and the number corresponds to the circuit number in the TM. Given the location it's probably the ground wire off the main engine harness - but a number from the tag will confirm it.Anyone know where this wire goes? I think it may be a ground. Does anyone know?
2A - Generator armature circuit (main positive line) - goes to AC SenseWire 2A
Wire 3B
Wire 74A
Wire 81A
Can someone help
It's pretty hard to bleed out the air with just a mechanical fuel pump that's active only when cranking. Some people will pressurize the tank to push fuel up to the engine to make it easier to bleed (there is a ventline with a check valve that would need to be blocked - or the check valve removed to use that vent for pressurizing the tank.Any ideas as to how hard it is to purge the air from an M998? And is it standard to have a rubber expandable plug in the bottom of the fuel tank as a drain? This one just has a plug no bolt to tighten it and leaks at will.
