scboolitcaster
- 4
- 18
- Belton, SC
Wow that's shiny! Urban camo
Because scboolitcaster asked earlier, here's a link to a bunch of pictures of the rebuild:Not to derail this Gun Ring thread, but it's the situation where the brake pedal gets more and more stiff until the brakes start dragging and eventually prevent the truck from moving. I believe it's air pressure that builds up in the air pack and isn't properly purging. It may just be a clogged port in the master cylinder. But a new master cylinder and a whole air-pack rebuild kit (at the time of this writing) are ~$150 for critical parts of my single circuit brake system (which means, every part is critical - lol).So what happened? The air pack piston stuck?
More info here:
http://www.steelsoldiers.com/showthread.php?73202-Help-Brakes-Stuck-on!
Thank you cattlerepairman, your well wishing means much to me.I hope the powder coating came out the way you wanted. I am with you on the frustration when outsourced work that you have to pay for does not happen as planned! At least you know that you have sufficient paint thickness on the hard top!![]()
HAH! I hear ya there!Wow. That looks great!
But now you're gonna have to powder coat the whole truck to make it look as good as the lid.![]()
Thank you! I'm not as skilled a some, but try to make up for it in effort and time. I hope it'll be ready! I've reached the critical point where I just need to work at it. Every-day. 14 days counting tonight.Nice attention to detail. It will be parade ready soon.
Thanks!Looks good Valence,
Makes me want to do the inside of my cab too while I have the seats out for the dual spring seat mod.
So for the tunnel covers:
- "Insulation on transfer case tunnel and transmission tunnels x2 (double layer of insulation if there's clearance enough)"
Are you planning on the sound deadener on the exterior side or the interior side of the tunnel covers. The clearance issue made me think the exterior side.
Sorry for the lack of clarity. My intent is to use the same thing on the outside as I'm putting on the inside with only two differences:Oh, okay, that's what I was thinking. And your using different stuff on the outside. Is the plan for two layers of the closed cell foam on the tunnels, or one layer of the Butyl, and then the closed cell on top of that?
