- 2,052
- 56
- 48
- Milford / Michigan
1300 is toasty. Are you using straight diesel? You have more hills in the common wealth than I have here in Michigan. I sure miss the hills.I don't have water injection on mine. I am seeing the 1300 EGT up hill as well. The numbers look very good with your water injection. Have you put Methanol in the mix yet?
I sure wish there were easier options for our trucks to install a bigger air cleaner under the hood. I start to pull up my air filter indicator (new style indicator located under my steering column) around 13psi /2000rpm. Just a little bit bigger filter (yes mine is clean) would make me feel better. I always keep my eyes peeled at junk yards and such to see if there is something that may work. Fab up brackets, paint it 383 green and it looks like it is supposed to be there. That's how I like it.
