indy76
- 0
- 0
- Lancaster, PA
![623654_6465_159_0001-1.jpg 623654_6465_159_0001-1.jpg](https://www.steelsoldiers.com/data/attachments/431/431239-00607760bc932d8abd86c1972ddb633d.jpg)
I attached a photo. I am pick up with a 1500 pick up.
I attached a picture to my original post. I am taking a 1500 pick up. Thanks for the info.If you bought a gen set on a trailer, whats the PU, (Power Unit) model number? There are several different types of trailer that could possibly carry the MEP-803A.
And yes, if only one gen MEP-803A is mounted on the trailer, one person can lift it. Not a problem. There is a PU that mounts two MEP-803a's and yes, you might be able to lift it by yourself. But you will not do it often, and it could make you look like you just induced a massive hernia. Normally, one person can hook this set up also, as long as the front jack leg works. Not always a given. Do you have a picture?
What kind of truck are you taking?
My on site contact (govplanet employee) helped me lift the tongue of mine onto my pintle. It wasn't bad. If you and a buddy go, it's easier. If it's just you, and the onsite contact helps you place the trailer on your truck, have a $10-20 bill at the ready in your front pocket to thank him.
A 1500 pickup is plenty. I had my 2009 ram 4x4 hemi, i could barely tell it was there.
Bring a 6" 3/8" bolt and lock nut with you. If the surge brakes aren't adjusted properly or siezed from long term sitting, you may want to lock out the brakes with the bolt. There is a 3/8" hole to place the bolt in at the front of the trailer. You may have to pull or push the pintle back or out to make room for the bolt. You will get what i mean when you see it. Bring a hammer to lightly pursuade the bolt in. It can be a tight fit. If your pintle sits low on your truck, it will trick the surge brakes into locking up prematurely and you will have a slightly skidding/hopping trailer. This happened to me but not enough for me to pull over and grab the bolt to lock out the brakes.
I brought a jar of axle grease, compressor, tool set, and small generator to run the compressor if required, a jack and jack stand and a box of nitrile gloves from harbor freight. My drive was from fort drum to albany. About 3.5 hours.
I did have to stop at the 30 min mark and load the bearings with additional grease. They were getting close to the point of very hot. I couldn't hold my hand on the hub for more than 3 seconds. The grease inside was fresh but i don't think there was enough, and i think the previous mechanic put to much preload on the bearings. Needless to say, boy was i happy i had tools. I didn't mess with preload as there was weight on the trailer, but i did mash as much grease inside the hub as i could. It seemed to help as the heat slowly reduced down to acceptable temps.
I was able to comfortably cruise at 65-70 no problem.
Think ahead, bring everything and a friend if possible, take your time, and you will have a pleasant recovery trip home. I did.
Your adaptor won't work. The trailer is 24v.Awesome info thanks!!!! I made a 12 pin to 4 flat adapter for the lights also. I am lucky on distance, only an hour drive for me.
The GL guys I've been dealing with have been loading me out with a forklift. I have a little low riding 4X8 trailer all of mine have been fitting on. The biggest I can carry is one of these 803a'sMy first meo803a came without a trailer. Really difficult to pick up...
Mine either, had to use forks on my tractor. A trailer would be nice.My first meo803a came without a trailer. Really difficult to pick up...
Thanks again. I just added to the thread I started. Check it out.Howdy,
The military uses a 24 volt lighting system. The military uses a special vehicle and trailer plug. There are threads here with information about making changes. I myself have cut off the military plug and throw on a cheapie RV 7way plug. Yes, you are only using 4 wires. ground, left and right turn, and running. All the bulbs will also need to be swapped out to 12 volt bulbs. Other have said, to get it home, harbor freight has a quickie trailer light set which you simply plug into your truck and zip tie the lights onto the end, and zip tie the wires down and be on you way. You need to go to the pickup prepared for the worse. Tires flat, safety tow chains do not reach, lighting, brakes, axles, bearings, can it be towed home? or on a trailer itself home?
Either way, by looking at what you got. The unit looks good with a recent reset. I do not think they swapped out the hour meter. By the looks and running of the engine, there is no way that engine has almost 6000 hours on it. At least your inspector knew what they were doing. Good all around pictures, even showing the unit starting, and changing the ammeter to show single phase. Be careful about the exhaust cover flap. We are having some good rains around here the last few days and short future before you pick it up. At least you know it starts and runs.
Trailer = It looks because of the reset, you have that unit on a newer trailer. The tag shows a 2010 trailer. incandescent or led bulbs? I do not know from the views.
Pintle , lunette height = If the height remained the same from M101A3 trailers to the M1102 type trailers, the height is around 25 inches. There are some forum threads about truck connections. Here is my thread about a 2007 LTT-TQG lunette and pintle height info
Engine = looks good, you will want to pick up some 3.5mm yellow stripe fuel return line. Your fuel return line is weeping. Fuel return line thread
good luck
