Towersafety
- 0
- 0
- Ludlow Falls, Oh
I have a 1970 M35A2. It has run great until we got it home from the Memorial Day Parade. Got it home and it just died. Thought maybe it was low on fuel so added diesel and it started. Used it a couple weeks later and drove it about a mile and it died. Added 15 gallons of fuel. Let the fuel pump in the tank run a min and it restarted and went a little bit and died again. Towed it to the barn. Could not get it started. You could hear the pump in the tank running. Came back out next day and still no start (cranks good). A week later same no start. I replaced the pump in the tank and it started right up and ran like a champ. Problem solved. NOT. Drove it about a mile and it died and will not restart. I checked the stop engine cable and it is pushing the kill valve on the engine fuel pump all the way in. When it is running it runs great. I replaced the fuel filters last fall and have maybe a 100 miles on it sense then. I looked through the TMs and could not find anything to help me troubleshoot (I may be looking in the wrong place). Any ideas where to start? I am pritty good with gas engines but diesels (multi-fuel) not so much. It looks simple enough just need pointed in a direction. Thanks
