I've been thinking of using plywood and studs so my ambulance top can go on and look normal from outside without the expense of buying the right pillars and nonexistant bows on the back....... Thanks for your service bikeman.It prevents the soft top from sagging onto your head. It also provides a mounting point for speakers for the radio set to get them off the transmission hump.
The best way that I've seen it, without doing a bunch of custom work, is to slide it in from the c-pillar support towards the front. You need to make sure you un-attach all the hold downs of the soft top onto the cross bars. you'll want to orient it so that the long part of the plywood goes the longer length of the vehicle, not the width. You can make custom setups, but for a simple 4'x8' sheet, that's how I've seen it.
I thought the bows stop the top from sagging on your head. If yours sags that much, you may want to look for a new one.It prevents the soft top from sagging onto your head. It also provides a mounting point for speakers for the radio set to get them off the transmission hump.
Are they screwed to the metal between the seats? Or up above you, under the softtop?I have a piece of plywood between the driver and passenger and another piece between the rear passengers.
Anyone know what those are for?
That would be me!A memeber here on SS has the correct M1035 soft top ambiance C-pillars for sale...
