TedO
- 7
- 18
- San Diego, CA
Hello, I have a M1008 and my running lights on the tail lights are out. Also all of the dash lights are out, but headlights, brake lights, turn signals still work. The fuse for the running lights, #16 on the diagram, a 20 amp fuse, blows as soon as I flip the blackout switch, even with the tail lights (head lights) off. I disconnected the rear harness from the harness that connects to the fuse box and runs along the frame, so all the tail lights are disconnected, and it still blows the fuse.
Next I wanted to disconnect the harness that runs back along the frame from the fuse box so I could test that for a short. The manual isnt very clear on this. It says there is a bolt holding the harness plug into the back of the fuse box?? I dont see it. I dont want to pull on it too hard, but it seems like there is something holding the plug into the back of the fuse box. How do I get this out??? Also, what is that red wire for?
What else should I look at? Is there something obvious I am missing? Also, I dont seem to be getting the switchable 12v from the fuse box any more. I used to have a tach and a cig lighter hooked into there, and it could be turned off and on with the black out toggle. Should I be looking at something with the black out toggle?
