tktsales
- 13
- 8
- Yanceyville, NC
Hi Guys, I recently purchased a nice 803A with 8 hours on it. A new set of batteries and some fuel and it fired right up like new. Seems to operate as intended. Still in process of installation and it has not seen a load yet. I am using primarily for backup power on the 240/120V 1ph setting but I an running a 208V 3ph outlet in my shop for occasional usage. This 208v circuit will be dedicated to that single outlet and NOT run through the transfer switch. My questions is there are 4 settings on the selector switch for 3 ph operation. L1/L2, L2/L3, L1/L3 and L3/N. I am not master electrician but I believe I need all 3 phases and the neutral so what is the correct setting on this selector for 208 3ph operation as I intend to use. Thank you for all input Ted
