Does he have any drop side beds?Found a bed, bows,vinyl top, all the mud flaps and mounts, spare tire mount, pioneer tool rack and mounting brackets as well as two sets of troop seats at a great price. If you are near South East Oklahoma and need a bed let me know, he has a couple of more!View attachment 636179View attachment 636180View attachment 636181
Well, It's not much of a deuce any more!! 1947 Plymouth P15 sedan body. When finished, it will have at least have air ride and AC!
!View attachment 636414 View attachment 636415
! View attachment 636415
Thats is super cool! Keep the pics coming!Well, It's not much of a deuce any more!! 1947 Plymouth P15 sedan body. When finished, it will have at least have air ride and AC!
Let me know how the shocks work out. Before I buy 3 new shocks want to know if its worth it.Preparing to install a pair of Monroe 34787 shocks on the front of the Deuce. I have been told this will give me some more front tire life. Then a Monroe 66104 shock for my drivers front seat. And then were off for a trip to Pleasanton CA and the MVPA Convention.
That's kind of funny (maybe):When I got my truck it was doing a little cupping on the front tires. I pulled one of the shock mounts and found them to be very difficult to move, so I called them good. I found the toe to be in about 1/16-1/8 if memory serves. I gave it a bit more toe-in and haven't noticed any issue since. Good luck with the shocks and hope to hear what you thought of them.
Personally, even if the original oil shocks are "good" (ie: not leaking), I'd advocate for replacing them. It's old technology and they will lose over 30% of their shock absorption because the oil "foams" during use. Modern shocks are much better, and a drop-in replacements are readily available. Better shock absorption, better job at keeping the tire on the road equals better ride, better steering, better braking, better tire life.When I got my truck it was doing a little cupping on the front tires. I pulled one of the shock mounts and found them to be very difficult to move, so I called them good. I found the toe to be in about 1/16-1/8 if memory serves. I gave it a bit more toe-in and haven't noticed any issue since. Good luck with the shocks and hope to hear what you thought of them.
- Are you saying it's too difficult to mess with, so you're just going to figure that they're OK?
or
- Are you saying that because they aren't moving readily you figure that they're not the problem?
The Monroe gas shocks showed up about 30 minutes ago. I changed the tires this morning so unless I run into some unscheduled Honey Do's tomorrow, I should be able to get the new shocks installed before it gets hot out. I replaced my drivers seat shock about a year ago with one from Those Military Guys. It's like this shock has double dampening, the shock is stiff both ways even with my seat cranked all the way down. I weigh about 217lbs, but I would probably need to be about 240/250lbs before the seat would be comfortable. So next I'll try the Monroe 66104 for the drivers seat and see how it works. Better I hope. Keep ya posted
