I've got my eye on a '72 m35a2 it looks really good I'd post pics but I don't think the forum will let me.
Forum won't let you? Do a search for pictures tutorial, I don't think there are any restrictions.
It appears to have a rebuild about 300 hours/ 3k miles ago.
First, without paperwork showing what was done and when (calendar wise), I'd consider this almost irrelevant. Sure, maybe the oil pump and bearings only have 300 hours, but if this "rebuild" was done 10 years ago, then there are dozens of seals that are losing their elasticity or their sealing or they're drying out, rubber brake hoses dry rotting, etc.
And the military had lots of rebuild programs-some were in depth, frame up rebuilds, some were "overhauls" and some were what I'd call major maintenance. Without some paperwork showing exactly what was done............ you don't really know and neither does the seller.
It has little rust it's complete and apparently runs very good. It's 500 miles away so I can't just pop out to take a look.
Ask him to shoot video. I do this for any truck buyer who is a long way off. I don't want someone driving 200 mph and be disappointed and start yelling at me.
As the title says, Can these trucks actually be made as reliable as a early /mid 70's pickup? I'd really like to be able to hop in one for a 3 day road trip without loosing sleep about breaking down.
That's a complex question.
Short answer? Probably.
Long answer?
It's never going to be a 2016 Honda Civic. It will probably be better than a 200K mile Yugo. It'll fall somewhere in between those two extremes. Where between those two points? You won't know until you buy it and start using it.
The newest M35A2 you're gonna' buy is a 1989 model, which is now 27 years old............ people started doing ground up, frame off restorations on musclecars in the 1980's, when they were only 15+ years old. Engines and major stuff aren't the only thing that wear out on motor vehicles. Everything wears out-that's why in the US alone, 10-15 million new vehicles are sold every year.
It can be made as reliable as a 1950's pickup.
Here's all the stuff that'll give you grief:
Radiators
Hoses/belts/fuel hoses
Injection pumps-they'll wear out (hydraulic head, plunger issues, etc.). The seals will go bad and they'll leak. The interior seals (o-rings) will fail and they'll bleed fuel into the crankcase.
Steering boxes will wear out and leak and be sloppy.
Transmissions do occasionally fail. 2nd gear is a weak point and I've had a couple break the input bearing retainer. Like any manual, bearings and synchros wear out, necessitating rebuild or replacement
Transfers-Occasionally, they start falling out of high range due to gear wear. About all you can do is replace it.
Axles-seals are a common issue and pinion bearings/seals are a reasonably frequent thing to replace
Brake system-6 wheel cylinders that can leak, 30+ year old steel lines that can fail (I've had it happen, not pleasant), hoses rot, master cylinders leak and airpacks fail. Honestly, any deuce you buy, I'd just accept that you're gonna' rebuild or replace everything.
Alternators-I had 2 alternators on different trucks die this week alone and on low mileage trucks. This stuff is getting old-one of them was the 15K mile (documented) unit on my '87 USAF deuce. Might only have 15K miles but it's 29 years old (I think-haven't found a date code). Takeout alternators aren't growing on trees and rebuild parts can be difficult to source or costly. Some folks are rigging civvy 24V alternators on their trucks and that is a more cost effective route, although it's not for me.
Wiring harnesses-I doubt many M35's went through rebuilds after the early Nineties, so the newest wiring harnesses are 25+ years old. I've had plenty of trucks where the wiring was just rotten-dry rotted, corroded wires, etc.
Engines-two kinds of multifuel owners: those that have done head gaskets and those that are gonna' do them.
Tires-just due to their design, they chew up tires, especially fronts. Ways to mitigate it are radial tires, lockout hubs, good shocks, etc., but it's kind of like how Porsche 911 models will always wear out rear tires quickly... it's just part of their DNA.
Rear suspension dogbones/torque rods-they are a wear item and they have rubber that gets hard and dry rots and if one comes loose, your day will suck. Replacements available but not cheap.
From my reading, they seem to have very steady breakdowns. But I will be the first to admit, I am very new to this hobby.
I'm not sure what the exact term is, but I suspect there's some "selection bias" here..........................
People post on internet forums to try and fix their problems......... the same way everyone who has a bad experience at a bar will post a negative review but only 1 out of 10 people who have a great time will post a review. Same here..... no one is posting "Hey, I drove my deuce 6 months and 5K miles without any issues". People post here when they have an issue.
To be honest I am about to purchase a late 50's pickup truck or a deuce. The intended use is for a fun vehicle for me and my boy to cruise on weekends, maybe the odd roadtrip/camping/fishing excursion, and maybe put it in a few local parades to advertise my construction company.
If you are conscientious about maintenance, these tasks are very easy for an M35 and I think you won't have much issue.
I know I can make the pickup uber reliable the parts are easy to get too.
Can I get the same reliability from a big MV?
I bought my '87 USAF M35A2C in 2011 with documented 11K miles (I got all the paperwork with it). Now has 15K.
I've done the following in terms of repairs / maintenance:
Flushed entire fuel system, vatted fuel tank, replaced all lines, resealed injection pump, etc.
Flushed and bled brakes
Replaced all tires
Pulled all 6 drums and hubs, new seals, packed bearings, etc.
Various lights, bulbs, flasher relay, etc.
All new hoses and belts
Alternator (as of today)
Greased everything
I would consider myself extremely lucky for a vehicle of this size and complexity at this age and mileage.
(Im not talking burned out lights or windshield seals, I'm talking catastrophic transfer case breakdown or a blown turbo. Major repairs)
Possible, just hard to predict likelihood.
thanks. If I'm allowed to post pics I will certainly put a few of the prospective truck
John
We'd like to see it.
