$25 Mudflap Install
70deuce
115
Franktown, CO
Installed mudflaps on the M998. Used one NAPA 24 by 18 plain black truck mudflap cut in half and a $5 dollar pre-drilled strip of angle steel mounted to the two bolts securing the light guards protecting the rear light wiring connectors. Very easy install. Did have to round off the square corner after cutting the flap in half. Razor knife did the cutting.
Lawdog734
Colbert, GA
Looks good, but they don't appear to offer enough protection for keeping debris from being kicked up. I believe that most states require 6-8" from the ground or enough protection to keep degree from being thrown back at a certain predetermined angle. I suppose it's better than nothing at all though......
70deuce
115
Franktown, CO
Lawdog I agree on the length. Its a start At least I have the mounting brackets installed. I am going to look for 24 to 30 inch length flaps (will measure from the ground) to get something in the range you stated. Figured I would get something on there for now.
Royalpower
Atlanta/GA
Good info to know. I do agree that it would look nicer if it was slightly wider and slightly longer. No matter what, it's better than what I had :).
