TheUziButton
- 0
- 1
- Dayton, Oh
I have an M923 A2 that will not inflate the tires above 15psi. I have even tried manually inflating the tires to 45psi and within 20 minutes all the tires are deflated back to 15psi. The ECU does not indicate any errors. The only thing that I can detect that is out of the ordinary is a whistling noise originating from the driver’s side wheel well when the PCU cycles through each of the tires but I cannot detect the exact point of origin. Is this a stuck valve? If so, where can I find it? Any help on how to resolve this issue would be greatly appreciated.
