Good job Daybreak !Howdy,
Tm's needed
TM 9-6115-751-10
TM 9-6115-751-24&P
The starter for a MEP-1030 5kw, and MEP-1040 10kw is nsn 6110015958949 cage 44940 p/n 11.131.457 STARTER, MOTOR, 24 VOLT.
They talk about using a lot of the same system to design the AMMPS units. The starter then again could be the same for the MEP-1050.
OK, I just looked it up, and it comes up showing the same starter for "Starter motor 24v, 5/10/15kw"
p/n 0191-2382 cummins power
p/n 04-20148 cummins power, and DOD
p/n 11.131.457 mahle letrika d.o.o.
p/n 11.131.457 cummins power
It says CENTRAL DIESEL, INC., 4600 DEEPWATER TERMINAL RD, RICHMOND, VA, 23234-2211 just got a contract for 45 units on 7/11/16, delivery 11/7/16. They might be a source.
Hi can you please share with me the oil and fuel filter types numbers, my unit is missing both thanx mac/mc please use libbysales@austin.rr.com to reply thanx mac/mcI have the TM/Parts for the MEP-1040 I can send you. Quite a few parts on these units will be the same. I have a MEP-1040 as well that I decided to keep for my back-up.
Link to video:
Yanmar OEM Lube Oil Filter, Part# 129150-35170 and Parker R15SHi can you please share with me the oil and fuel filter types numbers, my unit is missing both thanx mac/mc please use libbysales@austin.rr.com to reply thanx mac/mc
Thank you very much mac/mcYanmar OEM Lube Oil Filter, Part# 129150-35170 and Parker R15S
im looking for a radiator hose if you still have this unit for parts. Im pretty sure its part number 04-20796 in the manual. Thanksi have one with 200 hrs that i am stripping for parts, mostly wonder if the wiring is the same for all of them, i assume it may be.
MFG SKU | CAGE | Manufacturer | Type | Status | Role |
04-20796 | 30554 | Department of Defense Project | A | A | |
04-20796 | 44940 | Onan Corporation | A | A | |
A028U369 | 44940 | Onan Corporation | A | A |
been a long time, probably gone.im looking for a radiator hose if you still have this unit for parts. Im pretty sure its part number 04-20796 in the manual. Thanks
I was able to order the hose from cummins dealer. If you still have the unit, i might need some parts. Thanksbeen a long time, probably gone.
