profo
- 74
- 28
- jeanerette,la
Yes you have to losen band clamp and rotate turbo outletLooks like a lot of good work. Did you clock the stock turbo outlet?
The radiator had a built in oil cooler so I used it cause if I were to use stock oil cooler I would of had to lengthen the water inlet pipe that hooks to it and I didn't want to modify anything that if this doesn't work I can put everything back together as it was stock.Looks like it, and went traditional automotive style in-tank style, but I should let him answer.
Already had it just wanted to show the kit in case anybody needed to know what is was with this inter cooler everything fit great including the condensor and fans in front of inter cooler. Gun a run her tommorrow a see if temps will drop.Adding A/C too, I see!![]()
Thanks for the data. Is this stock fuel rate, or turned up? Apology if you already posted the answer.
Thats what's funny no smoke coming out and never did. Just ran hot all the time.Way cool (literally). Thanks, it is useful info. She should run a lot stronger than it was stock (?). How are you looking on smoke?
Where did u tap into the radiator for the line going to the overflow tankWell ran it today holding to the floor from stop and can't get it over 1150 degrees traveling down hwy while at 60 running a cool 900 degrees looks like it dropped temps by approx 200 degrees and it seems to have better acceleration also. Will hook trailer and put deuce on it and go for ride will see what it does with about 20k lbs behind it. Before it would run right at 1100 cruising without trailer climbing to 1200 on overpasses today stayed at 900-1000 on overpasses, I even ran it up to 65 mph and didn't go over 1000 degrees!
