ElvisArronPresley
- 0
- 0
- Harrogate, TN
you all are talking about a frame straightening / repair / alignment shop right? not a tire place that has an alignment machine?
Correct, a Frame straightening/repair/alignment shop, not the tire place.you all are talking about a frame straightening / repair / alignment shop right? not a tire place that has an alignment machine?
Exactly!If it is 2 inches out of wack, a level concrete slab and a tape measure should be able to determine if its a bad suspension , bent frame or rotted body mounts . I would narrow it down before shelling out money on having it put on a frame machine .
Finding 2 inches in a bent frame isn't rocket science , if you can read a tape measure . 30 years ago when this truck was built very few frame racks had lasers , they used a tape measure.View attachment 645035This is what the untrained eye sees when they don't know what to look for. View attachment 645036This is what a trained eye sees in the stars and constellations. Some time spending a bit of money for a professional diagnosis is less expensive then just throwing money at an unknown problem. And I think the owner is saying he has tried everything. I am just trying to help. And getting the answer/diagnosis right and correcting it the first time is easier then just shelling out money like you say. It may be an easy fix and it may be a repair that is not feasible or practical. But none the less it would help to hit/diagnose the issue the first time out. But I am a huge fan of tearing things down to the bear frame and rebuilding them from there. And that is about all I am going to say. Do it right the first time. Do or do not. There is no try.
They also used precision built machines that had extremely tight tolerances to check frames. The naked eye cannot see everything and sometimes it can be deceived by angles. "Parallax" comes to mind off hand. Also snapping lines on the concrete is fine if the concrete slab is truly level. I have never seen a truly level concrete slab yet though, have you ? Even our base alignment slab is off and the machine is adjusted to compensate for it. I would take it to the frame shop and make sure everything is OK. At the very least it will give you peace of mind that the frame is fine.Finding 2 inches in a bent frame isn't rocket science , if you can read a tape measure . 30 years ago when this truck was built very few frame racks had lasers , they used a tape measure.
Well at this point he isn't looking for precision frame straightening he is trying to determine if it is the body dropped , bad springs or the frame but again your the expert.They also used precision built machines that had extremely tight tolerances to check frames. The naked eye cannot see everything and sometimes it can be deceived by angles. "Parallax" comes to mind off hand. Also snapping lines on the concrete is fine if the concrete slab is truly level. I have never seen a truly level concrete slab yet though, have you ? Even our base alignment slab is off and the machine is adjusted to compensate for it. I would take it to the frame shop and make sure everything is OK. At the very least it will give you peace of mind that the frame is fine.
Well then you are the exception with concrete.Well at this point he isn't looking for precision frame straightening he is trying to determine if it is the body dropped , bad springs or the frame but again your the expert.
Have you ever put a laser on any of these slabs ? Apparently you frame machine you refering doesn't have close tolerances on the install . Over the years our company (general contracting but mainly concrete work) has installed many slabs for balancing machines for rebuilding dozer undercarrages and in local auto plants where the tolerances are +/- 1/8 of a inch . These were all a minimum of 10 feet thick with 5/8" rebar welded every 6" in a giant cage lowered in to the hole . These tolerances require covering in burlap and keeping hydrated during the cure process . But a good concrete company will have +/- 1/4" on the average driveway which is close enough to find 2" drop on a frame or rusted body . But I'm no expert just a guy that gets the job done .
No I'm not a exception most any company that does any industrial work can do it most power screeds are lazer controlled .Well then you are the exception with concrete.
I would LOVE to find someone that can pour that precise around here.
Of course driveways and precision machine slabs are two completely different animals.
I still recommend having it checked.
That way if it checks good, then continue looking at the other possibilities.
I would gladly do that before messing with cab bolts.
At least until I had to.
Well our last base was built in 1976 and I don't remember any Lasers then. In todays world your probably right, but I still don't see any driveways built with Lasers. That is quite interesting though about using Lasers to level concrete. My father and uncle where contractors and they would have loved to see something like that.No I'm not a exception most any company that does any industrial work can do it most power screeds are lazer controlled .
1/4" is extremely good ! I have poured slabs before and if you use the bull-float to much you can push to much material where you don't want it ! This laser mounted "screed board" sounds interesting though ! I wonder if you can rent them ?About laser use during construction, working as a laborer 15 years ago, the use of total leveling stations was common practice in site work/pipe laying around here, with tolerances of about a 1/4" and it was a rough outfit. No cutting edge technology for us.
That's just ridiculous. A simple brake job would only require all hydraulic components, new hubs, rotors and drums, new gearsets and master axle rebuild kit, lockout hubs, wheelbearings and new tires with a 2017 build code.Wow..only here can we start out with a little lean and get so far off course that were debating concrete slabs and the frame has to be bent and if someone can read a tape measure and spot the big and little dipper.
OP when your ready to do a brake job come back and I'm sure you'll be told to have your engine pulled and torn down along with your transmission for inspection because its just not as simple as your pads and shoes are worn out and its worth the piece of mind instead of just throwing money at a brake job
