MEP-8xx oil draining info
Daybreak
2 Star Admiral
1,522
775
Va
Howdy,
Any generator on a trailer should have the elbow and hose installed. It makes the oil change clean and painless.
Light in the Dark
6,775
MA
What is the size of this elbow, or what thread dimension should I be looking for? Gravity drain without control sucks. Thanks!
Daybreak
2 Star Admiral
1,522
775
Va
Howdy,
I believe its 3/4"
NSN 4730-00-940-0947 part# MS24519-7 ELBOW,PIPE TO HOSE
You just need a 3/4" pipe to hose barb elbow. The hose is listed being 18 inches. I just installed a 3 ft piece and then cut it to where I wanted. So, the length would drop right into a 5 gal bucket.
Light in the Dark
6,775
MA
Howdy,
I believe its 3/4"
I looked that up on another site, and came up with this
Nominal Inside Diameter Hose Accommodated (CWDW):
0.375 inches 2nd end
Nominal Pipe Size Accommodated (AAAR):
0.250 inches 1st end
Nominal Thread Size (CQJX):
Which a 3/8 NPT would have an OD of about .675 (3/8 ID). I bought two straight adapters at NAPA on my way home earlier... gonna try out the 3/8 and see if she works (and will report back).
Light in the Dark
6,775
MA
Daybreak
2 Star Admiral
1,522
775
Va
Howdy,
The trailer power units package came with a pipe to hose elbow for the purpose of draining oil. A generator skid can use this method too. Just a staright 3/4 pipe to hose barb piece works good to not have oil dribling along the side.
jimbo913
37
Maryland
I have seen everything from 3/8”NPT, 1/2”NPT and 3/4”NPT listed in this thread. Is anyone positive of the thread size at the outside genset housing so we can close this properly?
Ray70
7,166
West greenwich/RI
LITD is correct that the fitting on the outer gen enclosure is 1/2" NPT.
The confusion might be due to a couple factors, the holes in the engine itself are 3/8" NPT threads and the 002/003 series machines are 3/4" NPT threads.
Now, to add to the confusion... EVERY trailer mounted 802 and 803 I have ever received with an ( always unused ) right angle fitting and extension hose in the tool box has been a 3/4" NPT thread. So it seems that somewhere along the line the military forgot that the oil drain thread went from 3/4" to 1/2" when they went from the 002/003 to 802/803.
jimbo913
37
Maryland
Great point. I think my 803 had that hose in the trailer box and I recall it being very large and never using it.
